Brembo Mcs 19.21radial Master Cylinder - With M4 Calipers?
Discussion in 'Clothing, Gadgets & Equipment' started by m@tt, Nov 19, 2018.
  1. I bought one of these for the adjustability , as I have a hand injury , to go with the M4s and 330mm discs on my multi
    Now I think this is better suited to M50 calipers as it’s a 16mm piston ... not to mention I’m pretty happy with performance and feel with the stock MC
    Anybody used the MCS with M4s and can comment ?
    Thanks
  2. Yes had them, brilliant stopping power, the new version of the RCS is better now as allows finer adjustment between the two Ratios, as I had mine bang in the middle as it suited my style of braking, the 18 Ratio was soft initially and the 20 ratio was aggressive so middle was good.
  3. Are you sure the calipers you have are 32 mm pistons all of them, Brembo M4 have 34mm pistons.
  4. Sorry but I had the RCS, not the 16mm version you have.
