Has anybody fitted a Brembo rcs master cylinder to a 2011 multistrada ? Is there anything I need to know ? Any tips and tricks? Regards Chris
Put one on mine after the original failed, works fine but bare in mind you will have to dremel a LOT of the hand guard to accommodate it. If you’ve got the time and patience you can get it looking very neat. I’m not 100% sure if the rcs works with abs or not, hopefully someone can chime in on that. If you have any problems drop me a message, happy to help where I can
Many thanks , I hoped it works with abs or I wouldn’t do it. I assumed as it’s before the abs pump the downstream would all work as normal. But if someone could confirm before I crash and die that would be fantastic. Time and patience are not normal friends of mine but it’s a Christmas project so will give it a go and may if you don’t mind take you up in your offer of a pm if I get stuck . Did you notice any difference ? Cheers Chris
