By the way.......
Discussion in 'Supersport (1974-2007)' started by Ghost Rider, Apr 14, 2012.
  1. This is worth knowing...
    ...were you aware that you shouldn't get too much cr*p in the float bowls because I found another in-line filter..........
    ...........it's the little white nylon ring in the fuel hose tee-piece where it is between the carbs.......it just pulls out.....
    AL.
