Camper Halves Joining Screws
Discussion in 'Builds & Projects' started by HYPERBIMDUKE, Apr 16, 2019.
  1. Would you use stainless steel A2 screws for the 4 joining screws, (not main mounting screws),?
  2. What's Camper Halfes?
    Where Should I NOT Use A2-70 Stainless Steel Bolts ?
    A2-70 Should Not Be Used In Heavily Loaded Mechanical Or Structural Areas.
      • Areas Of Direct Loading On The Suspension.
      • Areas Of Direct Loading On The Steering Column And Linkages.
      • Active Engine Componets (Con-Rods, Crank Shaft, Clutch, Transmission & Power Off-Takes)
      • Active Gearbox And Power-Train Components.
    Any Nut Or Bolt Stamped With A 10:9 Or 12:9 Should Be Replaced With An Identically Rated (Or Higher) Component AND NOT An A2-70 Component.
  3. Sorry, caliper,
    bloody predictive text...
  4. Yes I was wondering that too?
    It's clear now
  5. Noo not caliper halves with stainless
