Howdo!! Can standard cams be re-ground to gain more performance? The cams in question are ST3 so no performance ones available. Heads are flowed (Standard valves.....for now). Any info advice welcome. Cheers Pablo
Simple answer is yes - you can regrind cams, build them up and regrind or base circle grind them. Talk to Phil Joy at Joy engineering. You will find him in a UK google search with a bit of patience.... ;-)
