Carb Setup
Discussion in 'Supersport (1974-2007)' started by jamie125, Jun 14, 2021.
  1. Hey all,
    Looking to get my carbs cleaned and rebuild/setup back to factory spec, anyone got someone they recommend?
    Thanks,
  2. Getting mine done by these guys
    Harper's Ultrasonic Carburettor Cleaning
    £120.00.
    Haven’t used them before and haven’t got them back yet so no idea in terms of a recommendation.
    #2 Carr01, Jun 14, 2021
  3. They're not too difficult to do yourself.
    A good place to start would be to remove all of the jets and other components and clean them in cellulose thinners. Ultrasonic cleaning can give good results but isn't strictly necessary.
    Consider replacing the needle valves and diaphragms. Check the linkages for wear. Rebuild with new gaskets.
    Other than float height, as long as the jetting is standard set up is largely done on the bike. Even if you send them away you'll still need to balance them as a minimum.
    Allens Performance are the UK agent and Mikuni USA has general set up manuals you can download.
  4. Thanks, they are currently with Matt @ Harpers Ultrasonic for a bit of TLC.
  5. #5 Borgo Panigale, Jul 19, 2021
