Changing clutch plates?
Discussion in 'Technical Help' started by nasty pasty, Aug 17, 2013.
  1. Hi all,
    Can anyone help with a PDF/ instructions showing how to correctly change the clutch plates on a 05 999 please?
    not very technically minded, but I'm determined to do it myself.
    Thanks
  2. Sorry just tied to post the link for the pdf but it didn't work . It is a simple operation to change plates though , take off cover , remove springs , pull pressure plate off , hook out all plates and replace in the same order with OEM , plates .
    #2 peter james, Aug 17, 2013
  3. Thanks Peter, having looked at it, it does appear to be pretty simple. I just assumed it would have been more complicated than it actually is.
    Cheers
  4. Sorry just tied to post the link for the pdf but it didn't work . It is a simple operation to change plates though , take off cover , remove springs , pull pressure plate off , hook out all plates and replace in the same order with OEM , plates .
    Hi, I did exactly what you r asking took plenty of photos when I was doing it and when talking old plates out I put them on a piece is string in the order they came out so I knew exactly the order they went back in. Just make a note of the depth of the springs showing above the collars so you don't do them up to much. Took me no more than an hour from start to finish.
