Diavel Changing Pin When Not Known?
Discussion in 'Diavel & XDiavel' started by Lel Howard, Apr 22, 2017.
  1. i know there is a pin code for when key fob battery low but when my bike arrives, if the previous owner has set a code, can I change it if I don't know what he set it to?
  2. According to the manual, there are 2 ways to change the start pin code.
    1 - know the existing pin, use this to choose a new pin. If you don't know the existing pin, then you can not change it using this method.
    2 - dealer uses their software to factory reset the pin to ----, you can then choose your own pin.
    The pin start code is not only for when you have a low battery on the key fob, but, you can use this method to start the bike without any key at all.
    If the Honda dealer is getting the bike serviced at a Ducati specialist before delivering it, get them to factory reset the pin, then you can select your own when you get the bike.
    Hope this helps.
  3. Yep, my thinking too, will email them now :)
  4. Turns out the Honda dealer has the pin code for it :)
