Hi I have a 1993 750SS. For my model the clutch master cylinder reservoir is rectangular and is attach to the lever assembly. I need to remove it. I've disconnected the banjo and the clamp but the choke control is still attached to it. Does anyone know how do disconnect this, I cant find anything in the workshop manual. Many thanks
Hi, I've managed to find the 2 screws that hold the choke control on to the clutch master cylinder. I now need to buy a new clutch hose but stein-dinse are out of stock. Any other suggestions?
If you are not bothered about OEM then Venhill supply any length stainless lines and banjo's in all sorts of configurations.Recommended.
