1200 Clocks Advice
Discussion in 'Multistrada' started by richard knight, Nov 2, 2017.
  1. I have a 2010 multi s and the main part of the clock has gone blank, the little window is still working.
    Will clocks from a 2012/13 multi work? They look the same
  2. I'd give your local dealership a quick ring bud'
    Prehap's stress you've been a loyal customer (if you have) & that you are slightly frustrated at this fault appearing. I'd hope they could offer some discount if its requires a replacement.
  3. I had a 2011 multi and learnt the hard way that s clocks don’t work on a 1200 abs. So I would aim to get same model . In the end I got a set from moto rapido that had been returned under warranty .
