Hi was thinking of getting a new set/ used sport classic clocks to fit on my GT, I like the white ones and I have a fracture in the glass Is it easy to change the clocks, make them work ok?
David this guy [email protected] will machine out and replace the glass. I haven't personally used him and it is expensive, but no more than replacing the clocks, changing the keys or chips etc etc. Something to consider.
Ok so although monster clocks look the same, they are not, different screw locations on the shell and a few other differences, so back to the drawing board
Ok I have now bought a second hand set of paul smart clocks and hopefully found a company in the uk that can clone my clocks, so then I can just change the pod back
aparantly you cant clone the clocks if they have a green circuit board, so maybe dismantle both clocks, pull the needles off and swap to the white faces, then put them both back together
