Clutch Case Removal
Discussion in 'Technical Help' started by gaz92, Sep 20, 2015.
  1. All,
    Anyone got tips for getting the clutch case (not cover) off.
    All 10 (is that right) bolts are out and I have given it a bit of a whack with a rubber hammer and tried knocking a bit of a lip (miss match in casings) with some hard plastic but remains very much stuck. I think this would be original gaskets and not 3 bond. Possibly heatwhich I have just seen on another thread.
    Cheers Gaz
  2. Assuming you have the clutch basket off? Try a piece of wood/dowel in the oil fill hole for some leverage and use the threaded holes (not those through into the engine casing) for the clutch cover - fit a vented cover as a handle if you have one? Should pull away fairly easily.
  3. Dukedesmo,
    Yes basket out tapped holes and seal visible, like the tip about leverage from a dowl in the oil filler hole. No vented cover available. Will have another go.
    Cheers Gaz
  4. Well I think heat was the deciding factor in the end, does not need too much though. I tried the bit of wood but it was not moving.
    I bought a M22 banjo bolt from ebay, few quid. Inserted an M12 x 20 lg hex head with corner ground off so it fitted through hole and wrapped the threads in electricians tape so it was a good fit and would not fall out.
    Screwed this in the filler hole - the hex contacted one of the socket head cap crews holding the oil pump on. I heated the joint around the front of the cover for about 5 mins, not that hot I could still touch it and wound the bolt in. The casing came off a few mm. Let it cool a bit jack it off again then waggle the casing until free.
    Cheers Gaz
