does anyone know where I can get a 10 tooth clutch tool to remove the clutch from my 899? Can’t find anything online
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.co.uk/ulk/itm/153394732447 ? Looks same as https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/303061160202
Both for 12 tooth clutches, for the 1199 and 1299. The 899 only has 10 teeth so they won’t fit. Seems like no one makes a tool for the 899. How does anyone change a clutch ????
Factory tool blocks the drum by fitting in and around the spring posts. Unique tool to 899. The 959, 1199 and 1299 are different.
I believe this is the tool you are looking for? https://www.ebay.com/itm/Ducati-Wet...635722?hash=item1c2834d68a:g:EYYAAOxyuCJRc7fT
I can get them from Ducati. That tool above that JiiBee has linked up to looks like it'd work though and it's a lot cheaper than Ducati one.
