1199 Clutch Slave Piston
Discussion in 'Panigale' started by John English, May 24, 2020.
  1. Hi after getting fed up with bleeding my clutch nearly every time I go out on it.
    I’ve replaced it with the Oberon clutch slave.
    On looking at my original clutch slave I’ve noticed a hairline crack on the outside of the piston I’ve ordered the new seals and o rings form https://www.bike-parts-ducati.com/ but I can’t find anywhere on the web where I can purchase the piston only does anyone know were I could purchase a new one
    Thanks
  2. I suspect that the OEM clutch slave only comes as a complete assembly as new. You could try eBay maybe? I was always under the impression that the Oberon unit was better than OEM though?
  3. Just installed an Oberon on my 1299. The action is a bit better. The main reason I fitted it though was my OEM slave needed bleeding every 3 months. Only just made it home from Silverstone one time....
