Clutch tools
Discussion in 'Technical Help' started by Loverobot, Nov 13, 2012.
  1. My new bike (to me) has a DP slipper clutch
    Has race setup on plates etc and want to put it back to road version if poss
    Have all the plates etc
    Dont have a clutch tool
    Will this do the job ?
    Laser 5340 - Ducati Clutch Hub & Drum Tool - Machine Mart
    Seems much cheaper than the others about
    Thanks
  2. So you want to change the plates? This won't affect the road/race setup plus you don't need a clutch holding tool either, just remove the pressure plate.
    For road/race setups it's all determined, well most of it is determined by the angle of the ramps on the drum which you would need to replace and you would need a holding tool then.
  3. As Freak says.
    The laser tool is cheap and works for getting the basket off.
    Bbut I think you maybe confusing yourself over what a race set up is. A slipper is a slipper, setting the stack height differently by using different thickness plates will alter when the slipper action is actuated.
  4. Sorry for delay in responding
    Not used a slipper before so prob am confused tbh
    At present it has what has been described to me as domed plates in and an amount or height that means it slips a lot whe setting off - the guy that had it was an ex racer and tracked it a couple of times = he said he preferred this
    I am looking to understand how the feel of the slipper would chage if I put the old 'normal' plates back in as shown in the DP instructions or whether there is an advantage to leave as is?
    He made it sound like a black art to set up the slipper proerly which means I dont want to mess without knowing what does what and why if you take my drift
    Its a DP slipper with 6 springs - the type that re-uses the existing springs if that helps?
