Has anyone else fitted these to a panigale (959 in this case) Few issues but the main one at the moment is regarding the brake cylinder, there is supposed to be a spring and bush on there but soon as I fit the spring it stops the brake from being applied. It works fine without it but wondered if ive done something wrong at this point?
Yes - you should have the spring. I fitted them (the pramac version) to my v2 Bayliss. The spring is there to return the pedal fully. It may be that the length of the plunger (the bit that pushes on the master cylinder piston) is adjusted wrong but sounds more like you've misfitted the washer that goes between the spring and the cylinder or maybe have the spring the wrong way around?
