1200 Compatible Swingarms 2014
Discussion in 'Multistrada' started by bungholio, Mar 26, 2022.
  1. I have a 2014 Multi S and need to replace swingarm due to not able to remove bottom shock bolt. What years are compatible replacements? 2010 to 2014 all the same?
    May need to replace shock too. Wonder about removing the Skyhook stuff and just getting used base model suspension or the Ohlins from 2010-2012.
  2.
  3. No, drill the bolt out.
  4. theres enough room either side of the bottom shock eye to get in with a recipco saw and cut the mounting bolt, cut either side, remove shock the threaded part normally just comes undone as its not this bit that siezes but the head section, once the shock is removed its a simple task to then drift the head out, its a PITA but far easier and cheaper than replacing the swingarm
