Going to be doing an oil change on my 2014 Multi Could someone let me know the size / part number for the sump plug washer please ? Cheers
All the bikes should have a washer. Some are spec'd with threebond on the threads also, but all have washers.
Absolutely agree. If I found a dealer not using a washer I'd be finding a new dealer, pronto. A mate re-used a crush-washer when he did an oil change - cracked the sump, so no washer at all has got to be worse.
Isn't a sump washer just a sump washer? https://www.ebay.co.uk/itm/Universa...e=STRK:MEBIDX:IT&_trksid=p2055119.m1438.l2649 https://www.ebay.co.uk/itm/Ducati-9...e=STRK:MEBIDX:IT&_trksid=p2055119.m1438.l2649 You just need OD and ID no?
Yep. Pretty much as well as material (copper or alloy) and the thickness, depending upon the bike there's 3 or 4 to choose from. At those prices though, may as get the right one from a dealer..... the most expensive one is about 70p
I just went to my local NTS car parts place, took the old washer and got a replacement of the same size for 25p
