749 Cycle Cat Rearset Questions
Discussion in '749 / 999' started by twelvexs, Feb 22, 2025.
  1. Was able to grab a set of CycleCat rearsets for my 749, but no instructions. Few questions if anyone can help:
    1 - anyone have any install instructions? Looked everywhere on the interwebs and no luck running across any. Yeah, I can figure it out, but wondering if someone might have a pdf or pictures of them
    2 - on the gear shift side, the factory pivot bolt goes into a sleeve in the lever. But on the Cycle Cat, there's no room for any bushing it seems - much smaller hole that fits the pivot bolt with very little clearance. I assume there's no need for a bushing? Just grease it and go?
    3 - There's 2 rubber o-rings on the original pivot bolt, one on each side. Is it right to fit those back when using the pivot bolt on the Cycle Cats or leave those off?
    Appreciate any help anyone might could provide - thanks!
    #1 twelvexs, Feb 22, 2025
