wow, problems coming in thick and fast, first the speedo, now dash cluster lights, turn signals, rev tacho not working. I believe these are all fed from fuse 6, blue wire to handlebar sw, then to key sw. Headlights/tail brake light work as on separate circuit. Apart from the obvious, check fuse 6, 10 way connector under the seat, Ecu tacho signal pin 24, pin 23 in bayonet conn, check pin p and pin t, check 6 way conn, check continuity, etc, etc....anyone had the same problem and what was the outcome? TIA.
I had exactly the same problem with my 998, brought about by hastily slamming down too many ill thought through wheelies. I re-wired the entire light/instrument cluster, only to find I had dislodged something within the switch unit causing an issue with multi plug r/h side. If I recall, the current, not reaching its correct destination, sought the route of least resistance to earth which may have been via one of the front indicators (faint glow when lights switched on - no lights). Pull your multi plug apart and look for obvious signs of corrosion, clean and re-pack with the proprietary grease. The speedo is a mechanical device however, so if you have been wheelying, you may need to replace the drive, as I did.
One of the two black relays that sit next to the battery, had the same problems on my 998 years ago. Cheap and quick fix.
I'm really hoping its fuse 6 or relay. Not got the bike at the mo...anyone got the part number for associated relay?...away with poor WiFi, can't load Ducati parts diagram.
Chris, you can get spurious and apparently unrelated electrical faults on the cluster with dirty or burnt contacts on the earth path, often intermittent rev counter, dash lights flickering with indicators and regular bulb failures which occur on different power circuits. The usual culprit is the earth pin in the main headstock to loom 19 pin (or 23 pin for later models) round connector below front rhs of the tank. It all earths through pin T on the older model (pins T and Z on later ones) and it is a regular issue not helped by the plug retaining water and the amount of stuff that earth path has to deal with. If you have a later model bike it is the same issue but there are two earth paths which help tie it down and make the circuits more reliable, pin T earths the clocks and pin Z earths the lights. Just open up the plug and have a close look for water, burnt or white corroded contacts, this plug needs a regular clean and the contacts treated with a contact preserver or silicon grease in any case. Relays are Yellow one 28740141A and the other 2 are 54140031A
I had the exact same issue around 6 months ago on my 748R. Spent ages looking over the bike and it turned out the round connector Denzil mentioned hadn't clicked in place. I disconnected the plug, cleaned the pins, twisted it back on and all was perfect again
At some point I am going to replace the whole electrics, main loom and headlight loom. Out of interest, I am guessing there is a slight difference between a central wiring loom for the 1.6 ecu and the P8 ecu? Mine is 1.6 ecu, seen some new ones for sale, but sellers can not confirm if its for 1.6 or P8.
Chris there are at least 3 main loom variations and three front loom variations for the 1.6 ecu bikes which include 19 pin and 23 pins round connectors for the front loom depending on the MY. The earlier bikes with 2 ph have different looms to the later ones and I think there is a variation for the three phase bikes between MY00 and from MY01 on. The front looms have similar variations and the injection looms for the P8 are different from the 1.6 fitted bikes. If the looms for sale are indeed new they should be marked with the part number which will make it easy to match. There are also variations between the bikes for example MY02 748R and 748/748S had slightly different looms. Finally there are variations in part numbers reflecting slight changes within the looms. If you buy new you would best order new with the correct part number for your MY. However the core of most are very similar and there is not that much required between the various 1.6 bikes to make the looms work except if you are trying to match a 19 pins system with 23 pins one. HTH
Thanks, great info as always. Will be sure to get the correct loom/s. For the price of new looms, I think its a worth while investment...my sps has turned 21 now! ...and plan on keeping her.
