1200 Dash Reset To Kilometres No Time Miles
Discussion in 'Multistrada' started by stewartie22, Mar 1, 2017.
  1. Help needed my battery went flat during the winter I have recharged it and bought an oximiser, but problem I have is my dash has reverted back to kilometres instead off miles have tried what it says in manual holding flash and reset button at same time but nothing happens can anyone please advise me what I'm doing wrong
    Cheers Davie
  2. Hold headlight flasher and indicated cancel buttons in as you turn the ignition on and you will get the units menu come up.
    You'll also have to turn DTC back on in the normal menus if I remember correctly
  3. As @Jimmyr says, you have to do this (flash+indicator cancel) with just the ignition on, not with the engine running.
  4.
  5. Hold the buttons before switching the ignition on
  6. Thanks Guys I was starting the bike first didn't read the instruction/understand the instructions correctly, I'll use the excuse they're not that clear
  7. leave it on so you can see 300up on your dash ...sweet
