Default Sort
Discussion in 'Forum How To's - create an Avatar/Event/Group etc?' started by Thelord, Apr 10, 2018.
  1. How do I change the default sort from last message to start date?
    Many thanks in advance.
  2. I assume you mean put the threads/posts in the latest order?
    If so look at the pic below. Click on the little arrow I've highlighted. That should do it.
  3. Thats it, can I make it a permanent selection as it always defaults back to last message?
  4. It should “stick” however if it isn’t then log out of the site, clear the cookies and then log in again. Hopefully that will sort it out.
  5. Will do mate cheers for the reply :upyeah::)
