Desmoquattro Base Gaskets??
Discussion in 'Technical Help' started by doogalman, Mar 2, 2015.
  1. Been rebuilding my 996 and need to know what the oppinion is of base gaskets. Install the gaskets dry or with threebond ??
  2. Threebond
  3. Gat
    Blimey, that was quick.
  4. The base gasket is more of a shim than a gasket. It will be difficult to seal without 3bond and you have nothing to loose. If you put it together without and it then leaks you'll have all the work to do again.
  5. Always with Threebond.
  6. Cheers
