Hello everybody, im seriously struggling with some tech specs and im hoping you all can help me out. I currently building a one off streetfighter, my next stage is fabricating the single sided swing arm. Im planning on putting an 8 inch wide wheel on the back and i have the option of using a standard 2015 Diavel axle. The details i could really do with is the PCD and diamter of the locating pins on the axle to mount the wheel on. I have an 8j car wheel i am using with a Diavel tyre so i am machining a custom hub and all that, and i have a guy lined up to drill said wheel to the required PCD but i cant find the specs anywhere. Does anyone have the numbers? Thanks.
