Dp Ecu Off Ebay...can It Blow Up My Engine?
Discussion in 'Technical Help' started by tboooe, Jan 2, 2020.
  1. I recently purchased the DP ECU for my 2012 848 EVO because I am adding Termi slipons and DP air filter. The ECU is coming from Ukraine and frankly I am little sketched out even though the part #s are correct and it looks like the right part. Is there any way I can actually verify that this ECU has the DP map on it? And if it was reflashed to some other crazy map, is it possible that my engine could somehow get damaged?
    #1 tboooe, Jan 2, 2020
  2. The expert on this side of the pond on this sort of stuff is @chrisw.
