Dry Clutch Conversion
Discussion in 'Technical Help' started by David Hales, Mar 21, 2018.
  1. ok how easy is it to convert my GT1000 to an open dry clutch?, is it a case of changing the engine case?
    Will a multistrada case fit?
  2. Mine has a kit fitted that i believe is for an 848.
  3. Ducati did a kit for the 848 which included everything needed, even a slipper clutch, and iirc fits the GT to. Was reasonable money to but is no longer available.
    You need the clutch cover, primary gears and clutch assembly.
    • Useful Useful x 2
  4. I think thats whats fitted to mine , kit complete with dp slipper clutch and ncr mag casings .
  5. Ok so it’s not simple, engine re-build, think I will ever leave it alone or just get a see through cover
