1000 Ds 1000 No Spark Or Fuel
Discussion in 'Multistrada' started by Alaska, Aug 17, 2019.
  1. well chaps after a great deal of pain finally found the fault. Faulty injector relay holder, which provides the power to the fuel pump and coils. At the same time cleaned all connections as previous posts, it would be easy to replace the relay and crank sensor, etc but just bell out the holder first might save you a small fortune. Good luck guys cheers alaska
  2. Good news Alaska, when you say holder do you mean the connector?
  3. Hi Chris
    Sure do, connector , good result
