Ds1100 Oil Seal
Discussion in 'Technical Help' started by 6274rico, Apr 14, 2023.
  1. Hi all, my ds1100 multistrada has developed a slight oil leak at the gear selector shaft, anyone know part no or where I can get one from in the uk.
    Cheers steve
  2. The part number is 93783.1524. It has been used on all Ducatis since the Pantah and is still used on current Ducatis. It is an ordinary lip seal measuring 18mm ID x 24mm OD x 8mm wide. You should able to get one from any bearing supplier.
  3. That's great thanks gor the ingo
