Sorry for the delay mate, ended up tidying the shed looking for it. Found it, it's not immaculate. The main item of note from the outsides the slight bubble, caused by being too near the lambda sensor bolt so it has burnt the plastic - you can see this on the inside, which i only gave a quick wipe to. The outside i took a bit more care, has come up to too bad. I've zoomed in on any visible damage. Just a scratch at the front, caused by stone chips i presume. Any use to you in this condition?
