Ducati 748/916 Coolant O Rings Size
Discussion in 'Technical Help' started by rob6539, Jan 11, 2016.
  1. Hi guys
    I’m looking to replace the coolant o rings on my 748 and would like to quickly confirm the size that I need to buy. They are the ones located behind the coolant inlets/outlets and blanking plates on the cylinders. I blindly purchased an O ring set, however none of them fit! :tired:
    I’ve also tried to measure the cavities the O rings sit in, at 20mm x 2mm thick. But I just wanted to confirm before I make any more rash errors.
    Any help would be greatly appreciated.
    Thank you all
    Rob
  2. main dealer ones cant be very expensive dude?? get um you know they fit then.
  3. Measuring the "O" ring is like trying to push a piece of string. Nominally it has to go in a groove that is 21mm id and 25mm od so is likely to be 22/26 diameter and about 1.9mm thick. Recently purchased from MR for not a lot. Oh yes and they are green in colour. Andy
  4. Thanks guys. I'll be honest, I normally try and avoid main dealers like the plaque, as you can normally get alternatives much cheaper else where (bearings being a perfect example).
    You have persuaded me :dizzy:
    Thanks for your input, it's very much appreciated
    Rob
