749 Ducati 749s Speedo
Discussion in '749 / 999' started by KC Dave, May 2, 2021.
  1. Hi, quite new on here so still trying to work everything out!
    Hi, the speedo on my 749s has stopped working does anyone know where the sensor is and how can it be tested? The rev counter is fine!
    Thanks in anticipation KC Dave
  2. As it is magnetic, check to see you haven’t got anything stuck to it. It is by the rear calliper.
  3. Changing the rear brake disc bolts can bugger it
  4. Hi, thanks very much, I'm going in the garage now to try your suggestion and hopefully it's a wire come lose! Regards KC Dave
  5. Cheers I'll check!
  6. Hi, thanks as my belts have just been done by the college in Hull and they told me they'd changed some of the bolts for stainless ones, Regards KC Dave
  7. Thanks I'll check
  8. That could be the winner
  9. Hopefully! Thanks again
