Ducati Connector Identification Help!!
Discussion in 'Technical Help' started by doogalman, Jul 9, 2016.
  1. Does anyone know what make electrical connectors were used on 748 916 996 998, monster 600/750/900, ST, supersport bikes of mid 90's till early 2000's.
    I am after identifying the male connector on a 916 series bike's ignition lock. It is the same as used on the above bikes from what i can assertain. I have the offer of a very cheap ign lock which works ok but the terminal block has been cut away.
  2. Most of them are Superseal connectors.
    Steve
  3. Just looked at Google images and the connector on the ignition lock looks a different make, sorry.
    Steve
  4. Yeah, old square type
  5. Ok i will have a look.
  6. PM me your details and I'll post you a cable off a knackered ignition lock. You can either splice it into the wires or replace the whole cable. I can tell you how to get the bolts out of the back of the ignition.
  7. Ok will do, but i'm in germany.
  8. No problem
  9. What a great forum this is.:)
