Hey guys I just bought a Multi 1200 DVT (15). Is there any independent software out there that will run on a laptop and access the ECU, at least for making minor setting adjustments. Not particularly looking for complex processes. I've had a couple of Triumphs in the past and used the TuneECU system, along with a suitable OBD connector. It was good for reading/resetting fault codes, correcting speedo errors, loading maps etc. What (if anything) is the best option for a 2015 Duke as above please ?
Google, jpdiag, not sure if this will be suitable for your bike but have a look for yourself and see what you think.
Im not sure if this will work on your bike but ive just accessed mine today with guzzidiag , mine is a 97 916 showing air temp , air pressure, revs , TPS voltage , TPS degrees and more. I think they use the same ECU in varies models but im no expert. obviously your bike is a lot newer but maybe worth a try.
I've also got a 2015 1200S. Jpdiag / Melcodiag does work but in a limited capacity. You can access, read and delete error codes. You cannot reset service indicator or desmo service. i think you can reset the pin code - have not tried it yet. You need to purchase the following two cables: https://www.ebay.com.au/itm/Ducati-Multistrada-Motorbike-Plug-Adaptor-for-Software-OBD2-OBD-Can-Diagnostic/133242783418?ssPageName=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649 https://www.ebay.com.au/itm/USB-ELM327-OBD2-Car-Code-Scanner-Automotive-For-PC-V1-5-With-FTDI-FT232RL-Chip/254000101234?ssPageName=STRK:MEBIDX:IT&var=553331044502&_trksid=p2057872.m2749.l2649 make sure to get the cable with the FT232RL chip in description Go to https://jpdiag.akress.com/ download the melcodiag software. Install, plug in, obtain licence key from him, happy days (It's freeware bu the way) There is a good post on the forum section of the website that explains what to do as your first steps http://jpdiag.xooit.eu/t1893-Getting-Started-with-Ducatidiag.htm There's also a few Youtubes explaining what to do search for melcodiag It's been well worth it. I had a DSS error on my dash. The error code clearly described the frt accelerometer cable had a ground connection making fault finding very easy.
That is a great help - thankyou. I was hoping for the service light reset, but it is what it is I guess. Perhaps it will come along later.
