Ducati Performance Rear Sets For 899 959 1199 1299 Panigale Part Needed
Discussion in 'Wanted' started by Sicilian, Feb 6, 2022.
  1. Long shot this, but thought I'd ask anyway.
    Purchased this 899 Panigale recently, its got Ducati Performance rear sets fitted which are great.
    It's been setup for 'Upside down gearbox' setting. I'd like to get it set back up to standard to gearbox, anyone have any spares for these lying around? I need these parts as outlined in the attached instruction sheet:
    Gearchange transmission tie-rod (straight gearbox)
    Screw M6x18mm (Q.ty 2)(straight gearbox)
    Thanks in advance.
  2. Just had a quick look and only thing suitable are ones from China, (don’t know if that’s a problem)…
    Don’t you have any local engineering shops? Can’t see them charging more then £30 / £40 for knocking one up. Screws are available online. Hope this helps.
  3. if your in the UK speak to the friendly bunch at Moto Rapido as they helped me source some spares a couple of years ago
  4. I might have the gear rod. Will check tomorrow
  5. Thank you for your help.
  6. That would be great, thank you.
  7. I have checked and I only have a gear change push rod, not part 5 in your post. Sorry.
  8. No worries, thanks for looking. Out of interest, whats the length of the gear change rod? Don't suppose its the 93mm rod by any chance?
  9. 119mm.
  10. No probs.
    I was after the shorter rod for those rear sets incase I ever adjust the height of the footpegs.
  11. rod -93 mm pn 11711411A
    rod-103mm pn 11711421A
  12. Great thank you.
  13. Are these 100% correct part numbers? Don't seem to be in Ducati's list.
  14. You will need to find a dealer with access to the corse parts lists. Speak to moto rapido as they will be able to help you out( it’s where I got my replacement parts from)
  15. Just realised, I need part 7:
    7) Screw M6x40mm (straight gearbox)
    @Nathanhu I don't suppose you have the part number for that screw please?
