i ve had this st2 for some years it s dine 42 000 its serviced too oftern a year ago this problem reared i ve had put in a new clutch a new master cylinder a new slave cylinder its been in the shop lots after 20 mile the clutch slips i ve also change and ajusted the clutch lever as well i am at a loss with this any information please regards norman
Has it sat for a while? A blocked reservoir return port in your master cylinder matches your symptoms but there are a few other possibilities. You have play at the lever when cold but reduces to no play when hot/slippage occurs? edited response to post below :-
i have change the master cylinder twice the only thing i havent changed the clutch line it be into pro ducati bbs ducati the new clutch came from rappedo if i was closer it whould go to brancatos in oxford but its pissing me off big time ive had ducatis for years all the parts ducati
