I have just purchased an Oddyssey 680 battery knowing it was much larger than the original, but have come to a halt in fitting it, Where on earth do you relocate the ECU? It won't fit on other side of battery box as it hits oil filler cap. Any body done this mod successfully? any photos? Cheers Dave
Check this out The only way to get your St4s to start up evrytime - Ducati.ms - The Ultimate Ducati Forum It is from the US Ducati forum. It might be of help
Interesting three-spring arrangement on the clutch! I am running four with no issues.... hmmm... ** EDIT ** Two missing spring posts.... :smile:
I have mounted mine to the side of the battery tray (at the back). It is a bit in the way of the oil cap when the connectors are plugged in but OK when you unplugged them. p
