I have a DP pressure plate to fit to my 749. They advise on fitting a slotted clutch cover to aid cooling and enhance the apperance of the the bike. In the final fitting instructions it says : When fitted, carry out the clutch engagements and disengagements to check and make sure that clutch is not "noisy" :biggrin: How do you know if your dry clutch is too noisy with a cut a way clutch cover fitted ????
