Had a service and replaced the timing and water pump belts and now the Engine Management Light is on showing a problem with both the Front and Rear Wheel Speed censor.Does anyone else have any ideas?
Have you tried moving the bike forward with ignition on. Sometimes this type of fault clears when the sensors detect the wheels turning.
I don't know it's with the mechanic but I will forward your suggestion on, thanks for the information.
