1200 Dvt Cant Select Passenger Mode Help
Discussion in 'Multistrada' started by NJW1967, Sep 12, 2015.
  1. Any one got a clue how to select two up on DVT I've been into riding mode it says it memorised but when I return to dash it still shows 1 helmet ???????????????
    Regards Neil
  2. Are you setting the mode tho rather than choosing the rider plus pillion?
    From memory...press and hold the ok (rhs of button) brings up preload setting then scroll down and press and hold again
  3. While engine is running, the far left hang switch gear press and hold down arrow, once in this menu press down arrow until riding mode you want then press and hold down arrow to select the riding mode you want
    Hope this helps
    Krumper :)
  4. Thanks a bunch guys this was not explained to me by the dealer just wanted to take my buddy out for a ride and could not find the required menu seems like it works without motor running
    Regards Neil
  5. It's a preload not riding mode tho isnt it you are after? Only had mine for short time, its around there somewhere
  6. Once you've been spoiled by this facility you can't go back to C spanners!!!
