Early Ducati Indicator Relay Please?
Discussion in 'Ducati General Discussion' started by Ian, Oct 30, 2014.
  1. My 93 Monster has destroyed its indicator relay (another victim of the reg' packing up. Also killed or injured was the ignitors, most bulbs and of course the battery!). Does anybody have a 2nd hand one lying around please? Its a pretty common fit from most Ducatis of the 90s it seems.
    Thanks!
  2. I understand if you are trying to keep it original then good luck
    If its just to get the indicators working then almost any of the electronic types on the Bay of Fleas will do the job, you only need to know if its a 2 wire or 3 wire
  3. I am trying to keep it original, although that's now becoming an aside! I tried a standard 3 pin replacemwnt but the flash rate was 180 per min - a fail on the mot. There's no led indicators, just normal bulbs.
  4. New genuine Ducati one bought off EBay. Should fit and give correct flash rate, as opposed to the 190 per minute my car part shop one did!
