Elbows
Discussion in 'Lounge' started by cherod, Aug 2, 2015.
  1. no i dont mean "out" or Jorge style "down",, but resting on your tanks ( 749 / 999 types in particular, but maybe also applicable to other sports types ),,, do you rest your chin / chest on your arm when just cruising... what speeds do you think it is adviseable to put both hands back on the grips,, i find it quite comfortable up into the 8s
  2. I have a 999, but I am having a hard time understanding this post.
    What do you mean, exactly?
    I can't imagine having my chin on my arm. If I was chin to the tank, I think I'd like both hands on the grips.
    • Dislike Dislike x 1
  3. just put your left arm on the tank, takes a lot of the weight off the arms, can even rest my head on it,,, not ideal if there are twisties , but ok otherwise.
  4. i think he means elbow joint and forearm resting flat across the tank , at 90 degrees to the (usual) direction of travel.
  5. Matey you either need stronger legal drugs or lay off the illegal ones
  6. now dont judge others by your own failings ;),,,,,, or would that be hobbies or habbits...
  7. hobbies, or hobbits?
  8. every corner I take I get my elbow down
  9. Welcome to the Forum Marc - do you know, I knew it was you all along :Finger:
  10. The only problem I have is with my neck at low speeds, from the effort of keeping my head up while leaning forward.
    A lightweight carbon helmet helped but I still find myself sitting up with just fingertips on the throttle, while low speed tootling. Arm on the tank would make this worse I reckon.
  11. on a serious note - yes I find my self resting my arm across the tank from time to time or have my LEFT Hand resting on the edge of the tank
  12. Working on this. , managed to get my elbow. In contact with my knee the other day. ( Long long corner ) not sure if this is progress or not !!! )
  13. Was it a round-a-bout :)
  14. How did you guess ,,,,,,,,,,,, i had to go right round because i was too slow at getting up and over the other side of the bike !!! And missed my exit !!!!
  15. Yr
    trying much too hard methinks...
  16. meh
  17. When I got tired while riding I would rest my left arm on the tank just to give my arm a rest
    It's hard resting the right hand as I slowed down and nearly fell off :)
    The only time my chin rested on the tank was on the motorway tucked into the windshield :Angelic:
  18. My early 60s triumph had a thumbscrew on the twist grip, so you could lock it at any given speed, like a super-crude cruise control.
    Never felt the urge to use it though - lethal or what??
  19. Heh. An old mate of mine had a Honda CB500T with a sticky throttle. It enabled him to take both hands off the bars, turn around and pummel the pillion rider, a mutual friend.
    Now that's lethal! :)
