Copied and pasted from the hyper area....if anyone has any insight that'd be peachy! As above - haven't had one of these before (evo1100). Not sure when It came on but its had a clean and SDoc'ing this afternoon after getting caught in ground water on Thursday night coming back along the m4 from Wales. Anyway cleaned it went out - everything fine apart from the dip beam had gone so went and got a new bulb thinking that might sort it out but no. While I was getting it dyno'd 6 weeks ago I mentioned to chris at CJS tuning that the error light appeared now and again but flicking the ignition off and on again would clear it. He said once he finished that the error was a fuel sender error. Havent seen it since until today. As I say everything works, it starts on the button, all the electrics are working....so, how do I find out what the error is....this im gathering will entail some sort of usb/comport device to plug into a laptop.... Anyone has a clue/punt have a crack at it with my pleasure.... Cheers.
Id just like to add to all of the above that im not seeing any message - which (going through the manual) I should be seeing as well for example like IMMO (which would be an immobilizer problem) Just the amber engine light, nothing else.
