Engine Management Light He
Discussion in 'Technical Help' started by Diavlo, Mar 1, 2015.
  1. Had my termi fitted to my hyper sp a week ago, came home fine, started it up today and the engine management light came on along with errors on the dash, looked in 'errors' and it says 'engine'. After a minute or so ticking over it went out, my curiosity got the better of me so I switched the bike off then tried to start it again and it wouldn't start, it smelled flooded, left it for an hour then finally got it started but the revs are fluctuating between 1400-1800 with the engine light still on! Is it anything to do with the termi and upmap? Is it running richer than before ???? Any help would be great
  2. Maybe tps reset required.
  3. Does the tps not reset on start up?
  4. On the 796 you have to turn the ignition on and off 3 times
  5. The revs fluctuating from 1400 to 1800 suggests that it might be related to the idle control valve (stepper motor)
  6. Quick update
    Bike started first time and runs ok with no errors so feck knows
