On my 2004 749, I occasionally get this error code coming up. From my research that points to Signal Panel Sensor. Can anyone shed any light on exactly what this is and if is a common fault with this model and should I be doing anything about it? Thanks, Daniel.
Common problem. Barometric pressure sensor built into the dash. Some people have had success with cleaning the dash circuit board with contact cleaner. I have found that cycling the ignition on/off several times clears it. Normally happens when engine is switched on, off, on within a short period of time.
Thanks Chris, nothing to worry about then. The bike is still under a warranty so maybe I can get a new dash on that.
