Evening All, have to replace my fairing fasterners joining top and bottom fairing as existing ones arent brilliant, got some off ebay but are not star fixing and I would have to drill out fairings to fit, can anyone point me in the direction where I can get the original correct size and the star tool as well please, many thanks and hope you have all had a great xmas so far
The correct fitting tool should be in the tool kit. I have loads or Torx drivers and bits but non seem to fit as well as the Ducati supplied tool. If you went aftermarket, CT do a decent kit but use an Allen key fitting instead. Not original but miles more practical.
You can still get the original bolts and the rubber coated nuts from Ducati and the torx bit is number 7.
Here’s the ones I have used https://m.ebay.ie/itm/Ducati-Fairin...-kit-748-916-996-998-/360274420795?nav=SEARCH
