Farting In Ones Air Box!
Discussion in 'Technical Help' started by Nelson, May 5, 2014.
  1. Recently my lovely bike has developed a little habit of farting/phutting into its air box.
    Typically this will occur at low revs, just off tick-over, you'll be pulling away from a junction or just putting the the power back on coming out of a bend, then fart and away! Not every time, but enough to cause concern/ irritation!
    Now, Google/internet wisdom suggests this is probably a result of running too lean.
    I would like to understand how lean running would cause this? I would have suspected this would be the result of poor timing or valve seating?
    I have Gunson on order and thanks to ChrisW access to the ecu trimmer.
    Any help appreciated! :upyeah:
  2. Try cheap things first. Run some injector cleaner and Shellmax through it.
  3. My 998 did this when it was new and it was due to running too lean, I only had stock exhausts then and it was as it came out of the factory. I had some major backfires\explosions out of the airbox on slowing down particularly for junctions and for give way signs.
    When I took it to Sigma performance for a service they identified it as the problem. I got round it coincidentally by buying some Termignoni's which came with a new ECU. But when it was running lean it really did seriously backfire to the point where I could feel it blowing through the rubber seal under the tank. Mine was purely a weak mixture and a Ducati dealer or similar should be able to sort it out.
  4. Mine used to do it and only after reading this I realise it doesn't any more but I now always run it on super unleaded whereas I used to just use normal.
  5. Thanks, I'll try some injector cleaner and some posh, non-Asda petrol...:upyeah:
    I'm still interested how a weak mixture can cause this?
    I'd have thought any farting or backfiring into the air box would be due to compression leakage of some sort?
    Cheers
    #5 Nelson, May 6, 2014
  6. I'm not sure of the science but a lean mixture will certainly do this.
    After I had my 916 gasflowed (valves etc. were perfectly setup) on first startup it was doing this massively until I richened the mixture. Running it with the airbox off there were flames blowing out of the intakes - not good if you have an over the intake filter or plastic fuel tank...
    Co readings were around 1.5 - 2% but once dialled up to 5% it ran beautifully.
  7. My 916 did this last year.Just a nats off closed throttle,pulling away or poottling through town,trying to look cool,well you know.I had a small amount of play in the throttle linkage,so swopped a newer one,set the TPS and it hasnt done it since.
  8. Exactly what mines doing...:(
  9. TPS is free.It would be an inexpensive place to start.
  10. Yup - done that...:)
  11. DD, was the 5% on the gauge or 2% baseline + 5%?
    Cheers
  12. 5% on the gauge, with the gauge set at 2% in fresh air before starting. Bike was then mapped on dyno etc. and baseline was good when measured by AFR.
  13. Cheers.
    The one I have is an old MK2 analog...What a fiddly piece of crap to use!:mad:
  14. Can't help but best thread title in a while ;)
