Afternoon all, I have a check engine light on the dash and after plugging it into Melcodiag it comes with a P0105 fault - Map sensor. do these go often or could it just need cleaning, the bike has been sitting idle for quite a while now. Also, where is it on the bike before I remove everything to find out it’s in eyesight thanks!
Do the change BEFORE it leaves you stranded on a remote palce where nobody can reach you. Ask me how I know.
Assuming it cuts out and won’t start! Is there just the one or is the vertical cylinder sensor well hidden
It starts but it never revs up. The other one is hidden under the tank! Wish that it's the horizontal one!
