So, after a small incident with a barrier at Rockingham, the 1199 needs a few bits. If anyone has any of them, let me know what you can do them for! Parts needed as follows: Lower triple clamp Right upper fairing (red) Red nose come Clear screen (oem or d/bubble etc) Carbon heel plate (right) Right dp bar end or a full set of an alternative or a lever guard. Left mirror Clutch cover (actual casing) Engine case protectors Spindle protectors etc Thanks in advance! Matt
Got an 899 nose cone in red if that'll fit. Got the upper too but think it has 899 on it, I'll check if you are interested. All in the garage in bubble wrap.
Cheers, I was enjoying getting used to the bike. I did 2-3 days about 8-10 years ago and that was my second this year so 5 in total.
No worries, I reckon if you ask the dealer for the part numbers for both that'll give you an idea. Let me know if you want it.
Yep, 80 quid plus postage? It's un-marked and came off a brand new 2015 bike, I did 100 or so miles on the road then stripped it to build a race bike. Drop me a DM if you're interested.
Unfortunately Simmytt's mirror is a throttle side - I need a clutch side. Can anyone assist? Cheers Matt
What is the damage to the lower triple clamp @Horico ? Just mentioning it as it is very easy to bend the stem so I'd advise buying a new one since you don't know what has happened to a second hand one so hard to be sure it is straight without properly checking it.
I think you did well getting it nearly upright having realized you'd messed up. Argh, you have done a follow up video..of the damage.
