Fork Stanchion
Discussion in 'Technical Help' started by Ivor, Feb 18, 2022.
  1. Do the fork stanchion come out of the headstock? If so , how, it's a m800 frame, c 2002
  2. Hi Ivor,
    The forks should drop out from the headstock when you loosen the 5mm and 6mm hex screws on the upper and lower yoke. If it is twisted, take out the axle spindle and they will come out one at a time.
    Jon
  3. Thanks Jon, the forks are out, I meant to say how do the yokes come out of the headstock (frame)
  4. Seen your message, thanks Jon
  5. They're off, thanks for the tips
