No not some odd issue requiring the blue pill but the bracket to which the horn is attached on my 2010 1200 multi has broken off, most likely due to a stress fracture due to vibration. I've refitted it to the rhs lower faring bracket as a temp measure so I can still beep at those who cross me . I highly doubt that ducati will be able to do a warranty fix on this as it will require a replacement frame part which would be a tad excessive. So anyone else had this issue and what did you do to sort it ? If anyone is interested I can pop up a picture of the retro fit.
